Sorry flipbro, after re-reading my comment it sounds like i was being a smartass. Wasnt meant as a poke.
Curious, my cousin called me and said " heard u gotta new boat! Older mercruiser huh? Ya well im looking at a new yamaha jet drive yadda yadda" always one in the fam who like to one up everybody! Lol!
A lot of the mechanics only see a Bravo every once in a while unless they are a big one. The one shop I used to do my gimbal bearing install even told me he doesn't work on Bravos when I asked him about my current boat before I bought it.
Alpha and Bravo use different transom assemblies. The bravo 1, 2 and 3 use the same upper, just change the lower
Ok so the motor would have had to be modified to accept a bravo mounting assembly.
The cooling system is also different between the two engine/drive
Edit: I just noticed all the corrosion discussions on page 3 and the installation of a bravo transom assembly to an possible older model 350 alpha engine.
You have to ensure there is a ground wire between the engine main ground cable usually at the rear stud of the flywheel housing to the transom assembly bonding wire (Continuity Circuit) like seen in the photo below....If the ground wire is not there between the engine and transom then the transom is not grounded properly and could cause corrosion damage sooner than later due to both the Anode and Mercathode (< if present) system will not be able to function properly.
To ensure the Continuity Circuit is able to work efficiently, it would be in your best interest to follow the Continuity Circuit found under the Corrosion Protection section of each OEM stern drive service manual such as this one for your bravo model for example, http://www.boatinfo.no/lib/mercruiser/manuals/mercruiser28.html#/556
Can you see its there in the engine compartment?
Never leave the boat in the water without a battery in the water, it needs to be their for the bilge pump.
The plug in I'm talking about is plug into shore power. You can still have some corrosion but not near as much as if is plugged in. The main issue is the B3 drive and the large amounts of stainless steel with the two props. The B1 doesn't have near the issue as a B3.
As for how fast you will go, IMO your going to easy hit 60 mph and probably a bit more. You have a 18 footer with an 5.7, it's going to move, be careful with it especially if you get much about 60, you could start to chin walk
