I have the engine out and gimbal housing off my 1974 140 sterndrive. I separated the bell housing and gimbal housing and am putting in shift shaft and arm, new u joint, exhaust and shift cable bellows, new water hose and new shift cable on the bench before re-installing on the boat. I ran the engine end of the cable through the shift bellows and threaded the other end into the bell housing (old-style on the forward side of the bell housing). I installed the water hose on both the gimbal housing and bell housing ends I installed the u joint bellows on the bell housing end and the exhaust and shift bellows on the gimbal housing end.
I then tried to slide the bell housing back into the gimbal housing and work the u joint bellows on to the tube on the gimbal housing, but I couldn't get the bell housing in far enough. It felt like either the water hose or the shift cable was preventing the forward motion, so I removed the water hose at the bell housing end and unthreaded the shift cable from the bell housing. Now I think I can get the u joint bellows on to the gimbal housing, but I don't think I will be able get the water hose and shift cable back on to the bell housing after I get the u joint bellows on.
The manual is a bit unclear when you are doing all of these items at once. Did I proceed correctly when I hooked up the water hose and shift cable before pushing the bell housing back onto the gimbal housing? If so, is there a trick to routing the water hose and/or pushing the cable through the bellows so as to not have the restriction I found?
