I recently purchased a lower shift cable kit for my Alpha 1, Gen 2 drive. The shift cable is screwed into the bell housing from the outdrive side, not the transom side.
When I was removing the old shift cable the brass nut that screws into the bell housing broke off and I had to drill out the old brass nut, so now I have to re-tap the bell housing to accept the new shift cable.
Most of the searches I've looked at refer to a 1/4 inch thread size, but clearly the nut on the shift cable is larger than 1/4 inch. Can anyone tell me what size tap I should use to re-thread the bell housing to accept the shift cable nut.
Thanks much
Legacy 11
Thanks much
Legacy 11
