tigger3650
- Apr 7, 2012
- 130
Ok, background. I was one of those dummies who didn't winterize his boat. To my defense, I am from Florida, where it didn't get cold enough to freeze in the block, so winterizing was greasing everything up, treating the fuel and making sure the outdrive drained all the way. I came back from deployment and immediately transferred to Maryland, in December and we all know what happened next.
Now to current time. I am pretty sure the block cracked in the usual place, between 2 and 3 just below the deck, based on the waterfall of water running down the block when it's running. Best fix, scrap it and get a new motor, better yet bigger motor, dreaming of a 4.3 MPI. Not likely to get the Admiral to sign off on the budget request for a brand new one. Most likely fix in the meantime, see if I can stop drill it, clean and "V" it and temp patch it with Marine Tex or JB Weld.
Here is the problem: I can't get the manifold off. All the hardware came out nice and easy (thinking this was going to be a breeze, then Murphy showed himself). I tried:
-a little smacking with a mallet
-a lot of smacking with a mallet
-a little tapping with a hammer
-then a bigger hammer
-a pry bar
-a crow bar
-a BFH with a 2x4 until the 2x4 was no more
-and all of the above with a little heat on the manifold side of the joint.
Now I have sprayed eve orifice with PB Blaster and will attempt again tomorrow night. Any suggestions would be highly appreciated!!
-a pry bar
-a crow bar
