DanDeltona
- Feb 13, 2016
- 22
I have a 1997 Mariah 21' bowrider with a 4.3 mercruiser I/O. I had it out on the water and all was fine mostly kept at moderate speed and also chugged along in the no wake zones. Everything ran and worked fine. When I stopped the boat at the dock and went to restart the motor made a loud knock starter stopped and it actually broke a starter bolt in the motor. Since this incident I have extracted the broken bolt, replaced the starter, replaced the plugs and oil. There were no signs of water intrusion in oil. After that, I started the boat and it started and ran fine on the trailer with the ear muffs. After it warmed up it would occasionally make the knock when starting and the starter wouldn't spin. After letting it cool down it would start right up and run fine again on the trailer. I went to the water to test out the boat started and ran fine until I went to give throttle and it wouldn't accelerate past 2,300 rpm. Didn't sound bad or run rough. Just wouldn't go beyond 2,300. Brought the boat back home and starter clanked when trying to start on trailer and then wouldn't engage. I put a new starter and new bolts as they were slightly bent and didn't want to risk breaking off again. Then, boat started and ran fine on trailer and went up to temperature slowly and was fine at idle and would rev right up. Started daily like this for 5 days straight. When I went to start this morning it started fine and I ran it for 3 minutes. Then I decided to try to start again after 2-3 minutes and it made a loud knock and now the starter won't turn. What could be causing this problem/these problems?
