- Jul 23, 2011
- 47,296
With vortec heads, you can run up to just under 10:1 on 87 octane. a bit higher on compression with 91 octane
running flat tops, vortec heads, and a comp XM268H cam, I was running 36 degrees total advance. Only pulled the motor to go bigger
I agree, balance the whole rotating assembly
