wpowell323
- Mar 29, 2009
- 75
serial number OM603659
This is the newer style distributor with the 6 and 8 in the base. I know to put the pointer at the 8. my question is how do I know if the motor is in the correct base timing? I have installed the distributor with all 3 marks at the based lined up and the pointer at the 8, but the boat doesn't have good power, it is acting like it doesn't have enough timing. The motor ran perfect before I had to replace the distributor. my question is how to check the base timing. I realize the computer controls the timing, but it still has to be synchronized someway so it is close before the computer can work correctly. I saw a link to a PDF explaining how to synchronize the distributor, but the link was no longer working. Don S posted it, if the link can be posted again that would be great.
