ormjgrouch
- Oct 8, 2012
- 144
Hope all is well guys.
2000 Chaparral signature 300
Dual Bravo 3 Mercruiser 5.7 efi
The incident.
First left the slip, I noticed my alignment was off on the steering wheel. While maneuvering out of my marina.
Got on to plane, no problem cruised for 5 minutes
Parked near a beach and anchored out enjoyed the beach.
Left the beach and started cruising and noticed my port engine RPM would spike high up to 5K and I wasn’t getting on plane, pulled the throttle back down and made sure my outdrive was all the way down. ( also have issue with my trim going up and down). Throttled up and rpm spiked high again up to 5K. so limped back to the marina with low speed and got back to the slip and shut her off. The next day I checked the port engine and I wasn’t seeing any black residue or smelling and burnt rubber. Bad coupler? Clutches? Lower cable?
I did go back out to "pump out" (arghh kids) and I had no problem maneuvering with both outdrive out of my slip, my alightment was still off.
FYI.....
I bought the boat back in November 2014, when I got all the paperwork from the marina, it states that the engine coupler was replaced on the port side on 06/2014
Thanks guys for taking your time in reading my problem and you advises/tips/suggestions.
The incident.
FYI.....
