New here and on my second season with my 1996 18.5 Rinker Capri with a 3.0LX and Alpha 1 Gen 2 drive. I winterized the boat and noticed nothing amiss but figured I'd remove the drive and plan to change the impeller at least. The drive was a real bear to get off and when I finally did I found a little water in the bellows and the gimbal bearing was rusty and notchy. So it appears the bearing and bellows are on the to-do list. I also had some noise at extreme trim and steering angles so I figure I should plan on swapping the U-joints too.
I'm a gearhead who has rebuilt all sorts of engines, transmissions and rears with the tools to do it. This is my first boat tho.
Any suggestions for additional items to service while I am "in there". Any must have tools or tricks to be used during this? I do have the merc manual but see references to some specific tools. In the auto world there is more than one way to skin a cat, I assume with these too.
Impeller
Gimbal Bearing
Bellows
U-joints
Thanks!
Impeller
Gimbal Bearing
Bellows
U-joints
Thanks!
