Just wondering the proper movement of the shift cable outer casing relative to the front of the shift boot (small end) as you move the motor trim up and down. Is it supposed to stay in place with the metal clamp or cable tie? If it is supposed to stay in place, would there be anything wrong with putting some perfect seal inside where you clamp it down to achieve a better water seal?
If the shift cable actually slides back and forth on the front of the boot as trim is adjusted, it would seem to me that water would get into the boot?
Thanks,
bob
Thanks,
bob
