ericcarr2000
Ensign
- Mar 19, 2010
- 903
I recently purchased a bravo 3 drive that has the transom shower on it but the bolt that holds it to the drive is missing. Can someone point me to a place to purchase the bolt & spacer?
Transom shower? Do you mean drive shower connected/bolted to the drive itself?I recently purchased a bravo 3 drive that has the transom shower on it but the bolt that holds it to the drive is missing. Can someone point me to a place to purchase the bolt & spacer?
Some use the stock bolts from Mercruiser but most switch to a different type of bolt.Yeah I mean the drive shower.
Have a photo of the shower and other bolt design in question to help maybe locate the original manufacturer.
As FT mentioned, can you supply a Pic?There's 1 bolt that attaches the rear cover plate that is where the shower is bolted to. It looks like it should be longer than the others and should have some sort of spacer.
