I found this NOS control unit online, advertised as Mercruiser PN 64326A5. It was originally depicted with the shift cable and wires coming out of the top of the assembly and the arm attached so as to appear to be for a port side application, rather than starboard as it was being described. When I inquired and pointed out that it appeared to be for the port side, they changed the photo to what I have attached and said the arm was just installed wrong in the original photo. The Mercruiser parts photos I have found appear to show the assembly with the shift cable and wires coming out the top, which would mean that the unit in the attached photo is shown upside down, except for the arm.
Does anybody know if the unit could be operated as shown? This would mean that when you push the arm forward, you are actually moving the shifter so as to put the unit in reverse if it were mounted "right side up". On the other hand, perhaps these were meant to be interchangeable from port to starboard by just flipping the unit "upside down". Anybody know?
