i have an old mercrusier sterndrive serial number 2584058 and I'm trying to find a shift cable for it. anyone have a good lead on where I can pick one up?
is the cable that you are suppost to replace it with for the alpha series or something special?I tried to buy a shift cable to my outdrive from around 1970. Got told that it was replaced with the new model which meant that I had to make a new thread in my gimbal housing from the back. (Since the old one was threaded from the front to be able to use the new wire.
FYI: thread 1/4-18 NPT and since it is conical be careful so you dont run it to far through.
Didn't respond to your question but it might help.
