ibrw1
- Nov 13, 2010
- 236
I started last week working on neighbors milkshaker. Cleaned out oil/water, put in new oil, ran in driveway with the flush muffs. 30 minutes. Checked oil. Looked great, no shake. Went on river for over 1/2 hour, got home, checked oil, no shake, level perfect. Next trip, Went on river 5 minutes, engine foaming all over.
Did compression test. All within 10 percent. No signs of water in cylinders, although there may have been. I do not know history of boat. I want to pull heads as a start, best guess, am I making mistake? What is procedure? I am almost positive that the block is good, the head gasket is bad. The engine would not start when he got it. He sprayed an entire can of ether down the carb running and goosing the engine. Bad fuel pump. Anyway ether is good if you leave it in the can.
So, what's up? Right track?
