starstuck1979
- Oct 4, 2015
- 4
I have a 1979 starcraft with a Merc 470 170 horse with a 470 leg been running strong for a year son took it out for a trip shut it down on the lake. the engine would not turn over turned out to be a failed starter relay replaced relay. tried to start engine turned over real easy I was not home at this point when I arrived home 25 days later I attempted to start it no go, pulled the plugs to do a compression test I now have 0lbs on all 4 cyls I did discover water in the intake and the plugs were wet with water when I pulled them.I put a 3/4 inch socket on the harmonic balancer to check rotor position for TDC there is a clicking sound coming from the engine as I turn it over by hand .This engine ran strong before this with the exception of bogging issues ordered a carb kit from Mikes does this sound like a catastrophic failure no notable sounds like valves hitting pistons valves all see to be moving the same range of travel any ideas would be really appreciated at this point as I am at a loss without to tear this totally down
