Justinweigt
- Sep 28, 2015
- 32
I am having a few issues with the shift cable assy. So I was able to adjust the shift cable the right way with the 6" from the barrel to middle of the hole. My question is on the remote control shift cable. I know you turn the barrel away from the end by 4 turns, but mine was not hooked up, it had the barrel all the way to the end. Is there a certain measurement I can use to set it correctly. I seem to have lots of play in my throttle lever from full forward to neutral to full reverse.
It does go into gear both directions but I have ratcheting at the prop both ways, can this be caused by the remote shift cable not being properly set?
I would rather not spend all night guessing and checking the barrel location.
Thank you,
Justin
Thank you,
Justin
