Electric choke conversion
75 merc 120 with Rochester 2gc carb, changing the old auto choke to electric choke, everything I've read about it says you can hook the wire to the alternator but when I tested it, it had power with the key off, don't want to hook it up there, is there another place I can run the wire to that's not hot with the key off?
achris
More fish than mountain goat
Not going to be easy. You're going to need to cut into the harness, near where the 10 pin Canon plug is. Looking for the white wire. Parallel off that one...
johnkom
The thing I don't like about electric cokes is that they start removing the choke before the engine is running. So I modified my 1976 233 choke to only work when the oil pressure was present. I also wired in the hour meter to work off oil pressure too. See attachment.
JK
jbcurt00
How the "H" do I delete a photo??
I'll delete the post and pix after copying and pasting the text into the post I'm quoting above.
Then just quote yourself and post the photo
achris
JK
Not a bad idea actually....
johnkom
Thanks, achris. I thought so. I simply used an automotive generic relay used for fog lights or a horn that has Normally Closed (NC) contacts. Wire the relay to be energized by the low oil pressure switch. When you turn on the ignition the relay is energized and opens the choke and hour meter circuit. Once the oil pressure switch opens the relay closes and energizes the choke and hour meter.
To moderator: When I post the 225+ kb .jpg schematic to the forum it shows up as less than 1 kb. Which is, of course, unreadable. Any idea why? Tried using Dropbox link, same result.
JK
achris
JK
Use JPGs of 800x600 max... (that usually around the 100K mark)...
