Lptexastornado
- Aug 31, 2015
- 3
Hi, got my 1999 Tige 21v about two months ago and love it. Two Saturdays ago we were out on the river andthe serpentine belt started splitting so limped back to the dock and that was it for the day. As we slowly made our way to the dock the belt continued to fray and belt particles got all over the hoses and my engine. Last week I replaced the belt and while I was at it I replaced the impeller, oil and spark plugs. I also installed a 10" sub and 600watt amp that runs the sub. The power is being pulled from the single boat battery at the back of the boat.
Once I got the boat put back together from the sub install, impeller, plugs, oil and belt repairs we went out last Friday to test it out. I started getting a softer audible beeping warning sound. All gauges were at normal working conditions temp, oil , voltage all normal. It beeps at RPMS 2500 -3000 and beeps every 3-4 secs. Sometimes it will beep 4 or 5 times sometimes only once. I can run it WOT at 4000 - 5000 RPMS and it won't beep but when I pull it back to 2500RPMS it starts beeping once every 3 seconds for a few times then will stop. We pulled the air filter cover and the round silver air filter had that black serpentine particles all over it. I cleaned it off with a rag and the beeping went away for the rest of the day. Went home later and sprayed brake cleaner in the silver air filter and blew it with the air compressor to clean it real well.
Put the boat in the water tonight to do a final test run before our big trip to Lake Ouchita for Labor Day weekend and the boat is back to beeping at me again at the same RPMS 2500-3000. Once again the engine seems to be running crisp and will run great no audible beeps or sluggish running at idle or WOT. and even at 2500-3000 RPMS it runs fine just beeps every 3-4 seconds for different durations then sometimes stops beeping at those RPMS.
Any ideas what could be causing these beeps? We have a 4 night camp out and 3 full days on the lake and counting on the boat for 3 families and I am hoping it runs good the whole time. Any suggestions would be great. I'm going to try to get it into a mechanic to scan the engine but not sure if I will be able to find one to scan it in the next three days. I'm fairly new to boating and just got the Tige and am getting hooked fairly quickly!!!! They are way to much fun for me and my 5 yr old and 3 yr old!
Engine serial # is 0L390830
Thanks in advance for the help.
