I have a problem on a 2000 Chaparral Signature 27 with a single Mercrusier 7.4 MPI (with a bravo 3). This is a new boat for me this year but I obtained the maintenance records for the last two years. The issue has been going on for at least two years and 60 hours of run time. The symptoms are: loss of power, cannot throttle beyond 2500 RPMs, stalling, stalling and NOT restarting (had to be towed in 3 times), backfiring, hesitation and skipping. It?s had three mechanics (one a ?Mercruiser certified mechanic) work on it. The problem goes away for a few hours of run time (3-15 hrs) but ultimately comes back. The part swaps have been: IAC - MAP /R&R, Fuel Pump Cooler Kit, Fuel Pressure Regulator, Fuel Pressure regulator (again)/Fuel Rail rebuilt (fuel pressure 38 PSI), distributor Module/coil, Knock Sensor, remove/clean/replaced, Cap/Rotor, Fuel Pump Kit (pump/cooler), PVC, Oil sending unit, and Temp sending unit. Currently the fuel pressure bounces between 25 to 33 PSI. I?ve contacted Mercrusier and was told to ?Take it to a certified Mercruiser Mechanic? ? big help! Does anyone have any other idea?s other than to take the engine out and swap it for an engine with a carburetor?
PS: sorry if this is in another post. If it is I could not find it.
