Okay fellow boaters I have another issue. My boat in question is a s follows:
1989 Sea Ray BR200
Merc 4.3LX Thunderbolt IV V6
I have had intermittent issues with the boat dieing while running. The issue always presented itself as no spark coming off wire from coil. I did utilize this troubleshoot but am stuck on few things.
http://forums.iboats.com/attachment.php?attachmentid=131166&stc=1&d=1328016740
1. I have 12v at the pos on coil
2. The white/red wire that goes to distributor goes to the inside of the cap. DO I REMOVE THE CAP FOR THOSE TESTS?
3. Same for the Spark Gap Tester test...Do I need to remove the distributor cap?
4. I did buy a new coil. I put it in and it fired right up. Then it died after 5 fins and had no spark off the new coil. I came back 15 mins later and it fired up and ran for hours of tubing. Even refilled the tank once. The next day I came out and I get nothing from the coil.
Thoughts?
1989 Sea Ray BR200
Thoughts?
