I have, what I believe to be, a 1978 SeaRay SRV 207. What I do know is this the Mercruiser V8 350, 260 hp.
I have 2 issues:
1. I need to identify what Stern drive parts I need as I need to do impeller, bellows, etc.
2. Every trip I use the boat, I get moisture that accumulates under the distributor cap. Boat runs like **** until I stop, remove cap, wipe out moisture, restart.
From what I can find, the correct cap for this model does NOT use a vented cap. Other engines apparently offer a vented distributor cap, but not here. Ideas?
Iboats states the correct cap is 18-5389 but this is not vented.
-Engine Tag: Model: MCM 260, Serial: 5948949
-Transom Plate: Serial: 5934376
-Gimbal Housing: Serial: 5934376
All of this appears to be original.
However, about 10 years ago, my dad replaced the stern drive with a reman unit.
I need to do the impeller, bellows, ect but I don't know what parts to order.
My info on the non-OEM stern drive are as follows:
Stickers on Stern Drive:
-1:47, OA839251
-Alpha 1 1.47 Ratio F: *1FC07984*
-Service Gear Assembly *1RC20575*
I can post additional pictures if needed
I have 2 issues:
-1:47, OA839251
