Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
experience with Lehr Motor
  • experience with Lehr Motor
    I bought a 5hp long shaft for our sailing club, So far they have put 80 hours on it.
    A couple of small niggling problems the factory fixed , the Kill switch died, Lehr supplied a new one.
    The defective switch had never been tightened properly and had fallen apart ( Qa Problem?) the new one now has 20 hours on it no problem
    A mixture drifting problem was traced to the screw thread on the tapered needle in the carb being too slack. factory suggested a drop of Loctite, and told me if that did not work they would send me a new carb slide assembly.
    The first clue that this is going on , is that the motor will not idle properly.
    Other than that it works fine , starts every time, and as the gasoline motors wear out or get messed up by the gasohol, I will replace them with Propane motors.
    Brian Evans.
    Re: experience with Lehr Motor
    I saw these at the boat show and was looking at their 2.5hp as a kicker for my boat, great idea and for the convenience of the 1lb bottles I would strongly and will consider one
    • #3
      Following up on my experience with the Lehr 5hp motors. this is now two years later. After I had run one motor for about a year with no problems other than the niggles with the kill switch and the mixture. we bought 3 more. The first motor ( the original.) ran about 700 hours then started having erratic starting problems. this was traced to overheating of the motor. we have a very kelp prone area and it is possible to get a kelp leaf wrapped around the lower strut cutting off the cooling water, the engine just died, the offender saw the kelp leaf wrapped around the strut , took it off, and restarted the motor, however the damage had been done , it was never the same after that. I finally took it back to Lehr for evaluation, they offered me a refurbished motor in trade which we took, they said the motor I took in was beyond repair. I now have another casualty one of the 3 motors we bought has died at 448 hours total time with a thrown connecting rod, I am stripping that motor down now to find the cause, I will post here when I get the results. It should be noted that I am chief of maintenance for a sailing club and have 16 boats to look after, 4 of these boats are now fitted with the 5hp Lehr motors, and the members will play musical boats to get the propane powered motors , because they are much easier to start than the gasoline powered motors.
      • #4
        A good follow-up report, Brian. Thanks.
        How do the Lehrs compare maintenance-wise against the gasoline motors, barring kelp and ease of starting?
        BOAT SPECS FORUM HELP STARCRAFT FORUM SHOP iboats
        Please, no PM's (Private Messages) regarding boat/engine problems.
        That is what the forums are for.
        Only forum/moderator issues will be answered in PM's.
        • #5
          It sounds like your experience has been very good. Most outboards, especially little ones, never see those kinds of hours. Not to mention you have a bunch of "Blow Boaters" running them.
          Thanks for sharing.
          • #6
            Edit
