I have a 120HP V4 Evinrude that typically runs pretty good, except after it's set for awhile. When I first start it, it sounds fine, but when I go to open to full throttle it acts as if I've only sped it up just a little over idle. It sounds like it's throttled up, but I'm only going about 5 mph (when full throttle is 30+ mph). I have tried maxing and then backing off the throttle, several times, back and forth and it just refuses to open up. So I'll set it at full throttle and let it putt along, sometimes for 10 minutes (if it's the first time out for the year), and all of the sudden it just takes off. Then it will run great the rest of the day. It's done this for the past 2 years now. Usually when I run it day after day, it will run fine, except for the first day of a trip, but I did have one instance recently where it acted up two days in a row. I treat every tank of gas with Sta-bil. I've recently replaced the fuel line. Does this sounds like maybe a fuel pump or something else? Thanks in advance. Great forum. Have been reading for years.
