johnboy65
- Jul 22, 2015
- 10
I have a 1956 Johnson AD10 on my 14' tracker topper jon boat.. The motor starts perfectly, idles fine, shifts great, and is as pretty as a Dolly Parton in a red halter top..I'm having a problem with my advancing of the throttle.. The carbs have been professionally rebuilt and its been converted to an external fuel pump with preformed hoses that aren't kinked.. The motor almost acts like a spun prop situation.. Low RPM's and it pushes fine..
As soon as I hit 3/8 throttle the transom vibrates and acts like the prop is cavatating in air pockets..if I advance even more it acts like the packing on a hub would if it was spun out.. Yes..I'm a newbie here.. Any help or suggestions would be appreciated.. Thanks in advance!
