dies to a crawl when you hit the gas 60hp '97 Evinrude
mcktimo
Runs pretty good at idle. Will spurt like its going to go but then dies to a crawl with a throaty moan. I just pulled the carbs and went through them, changed the fuel filter, swapped out line to tank...nada...
last week...
Running at 'no wake speed' engine sounded good for 9 seconds then rough and throaty for 12 seconds for the entire 10 minute ride to the boat ramp. Varying speed slightly didn't change the pattern. First time in for the season was the day before and it ran fine on a little trip to the beach. On the return trip it wouldn't accelerate so I eased back and limped home at low speed hoping that I wasn't starving a cylinder and scorching it. Now it is back in my driveway.
The engine is a '97 60hp (E60TLUEA) 3 cylinder carbed with vro2.
The gas tanks were clean and dry with new fuel. None of the system check lights came on though they cycle on for the self test. I can't be totally sure that the oil level went down since I only ran 2-3 gallon of gas. I had oil in the first 6gal tank but switched to the pure gas tank when it started acting up; no difference.
Got this engine last year, about 15 hours ago. Changed the fuel filter and rebuilt the carbs back then before I even used it.Ran a 'storage mixture' in for 15 minutes at the end of the season. So far...
-plugs look similar to each other
-compression is 140, 140,140
what should I try next?
wildwalleye
It will be either gas or electrical. Check for things like a bad ground on the coils (loose coil), you can try pulling a plug wire and see what that does to the running so you can at least see what cylinder you are having troubles with. If nothing changes on that then you know to check items that effect all of them. Being that you switched tanks, fuel filter and rebuilt carbs I am leaning more electrical rather than fuel. I am not a big fan of "storage mixtures". I run some fuel stabilizer in my last tank of fuel and that is all I ever do. My motors (9 of them) sit out in the Northern Minnesota weather all winter and usually fire right up in the spring. In 23 years I can count on one hand how many first time season use problems I have had.
mcktimo
spark jumps 7/16" and is pretty snappy. Hitting the choke makes it die. Pulling the plug wires one at a time shows that each is contributing (at low speed). In the video below I am put it at WOT then don't touch it.
jakedaawg
Do fuel pressure tests. Try squeezing the bulb while acting up. Double check your carb work.
mcktimo
Not sure how to do fuel pressure test but squeezing the bulb at WOT doesn't help and the carbs have been done once by me and once by a evenrude tech
mcktimo
Turns out it was the fuel pump. When Jeff (of Diamond Marine) watched the video it pushed him back to thinking it was a fuel problem; the slow repetition of surging and dying out did not seem to be electrical to him. When he took it out, he too pumped up the bulb when it was dying and it had no effect; so the common wisdom that if pumping the bulb has no effect, you can rule out the fuel pump turns out not to be true for these VRO2 type pumps. My mistake was to only check the choke at low speed. I though I was verifying that it wasn't stuck on but Jeff choked it at full-speed-dying-out and it came back to life. That was enough for him to decide it was the fuel pump.
So I spent the afternoon fishing in beautiful Ipswich MA, $1,200 poorer and with 4 weeks of summer having slipped away. $368 of it was Jeff repeating what I'd already done, plugs, fuel filter, rebuild carbs, change out the tank and hose. You see this kind of 'professionalism' all over our culture, from medicine to mechanics. The next $832 was 3 hours of labor + the VRO2 pump marked up 25% over what you can get it for from marineengine.com. I don't think they got rich off this job, between 2 trips to put it in the water, they probably spent more than 6 person hours.
So I learned a couple of things about diagnosing. Turns out there was no magic bullet of high speed tank or fancy test equipment. The two likely scenarios that I didn't want to get wrong were power pack or VRO2 pump. I could have bought both of those high price items + a coil, carb kits tank, hose and filter for less than 1/2 of what I spent at the certified tech. I shouldn't have chickened out, I was afraid to be just an (expensive) part replacer. Oh well. Thanks for all your help. Happy boating.
