I'm replacing the impeller on a 1979 Evinrude 35HP long shaft that I recently picked up. Model 35903A, serial number E002229. I've got some photos below. The impeller that I took out is the one in the cup with the round pin. The one that got to replace it is the one with the ridge and the wedge. The last photo is the shaft, showing the flat at the base where the impeller sits. Is the one with the ridge and the wedge correct, and the original owner had an incorrect one? If so, how do the ridge and the wedge and the flat spot on the shaft fit together?
Thanks!
Lewis
Thanks!
Lewis
