A 1957 Johnson uses a twin line fuel hose to pressirize the the tank and force fuel into the motor.
Unless its had a pump added, it doesnt have one.
If ones been added, you should replace it w the same pump
Very common mod to swap to a fuel pump and run single line fuel hose
