I have a mid 80's 115 e-rude, it has 110 compression on all 4 cylinders, and good spark on all 4 jumps a good 7/16 gap on all 4 cylinders. when running if I pull the spark plug boot off of the strbd cylinders there is a noticeable change in rpms, but when I pull a boot off the port plugs there is no change at all ? So does this mean the port cylinders are not getting fuel? I'm not sure how the carbs deliver fuel to these v motors I thought that the top carb sent fuel to both top cylinders and the bottom carb sent fuel to the bottom cylinders is this correct? Anyway something don't seem right any thoughts/help most appreciated I have very little experience with the bigger motors this one was a free-bee.
