First I want to say thank you in advance for any advice you can offer on resolving this issue. I've spent $$$ for the local Johnny/Rude expert to guess at my issue and I've read countless threads on this and other forums, and I still can't pinpoint the problem. I'm hoping this thread will serve to not only resolve my issue but educate others as well.
I'll start with a quick "bullets" of the issue at hand for those that want to get right to the point, then go into detail below on what led to this point and where I'm thinking I'll go next.
Boat: 1989 Wellcraft Sport (aka V18, Fisherman) Center Console - 1800lb dry weight
Engine: 1987? Evinrude 150XP V6, 2-stroke, 3 carbs, VRO disabled (premix), hours unknown, not ran in about 4 years, recent compression test all cylinders +/- 2psi from average but average was around 77psi
Water separator: None
Prop: 14.5x19 aluminum
My background: 4th boat, a few hundred hours (engine time) experience (including another boat with an Evinrude V6 200 Ocean Pro), above average mechanical inclination but NOT a grease monkey
The good:
- Boat starts relatively easily but requires using a fast idle via the shifter (in neutral) to keep it running until it warms up
- Idle is OK after warming up, no sneezing, backfires or cutting off, not the smoothest in the world but no *apparent* misfiring - seems similar to my old 200
- WOT yields 44mph with 2 onboard and light fuel and equipment, RPM unknown (tach broke, will replace) but I'd guess 5000-5500
- Seems to make good power and run smoothly at or very near WOT, fuel usage seems about right (maybe 10gph WOT)
The problems:
1) Sometimes unable to accelerate to plane, engine bogs down and will die if i don't back off (happens at some point during each outing, and will happen repeatedly for a few minutes then will clear up)
2) Unable to push up on the trailer, it bogs down every time as the throttle is advanced (I presume due to more load on the engine since the boat isn't moving)
3) When trying to maintain plane at a lower throttle, engine runs rough or feels like it is surging
4) At one instance on my last outing, it would drop a little RPM when the trim motor was running; hasn't happened before or since (maybe ignore this?)
Background: Got a great deal (I thought) on this boat as a trade for another boat that I only had about $700 in (it was worth more). Engine ran and revved OK out of water. It was transplanted to this boat from a fish and ski. Did a lot of cleaning and replacing various accessories, swapped out the trailer, etc. First order of business engine wise was new lower unit lube and impeller swap (by mechanic). Lower unit fluid looked good. Added some fresh fuel to what little was in tank (internal tank, should've drained but didn't).
On the maiden voyage I noted that the tach was jumpy and inaccurate. Idle and "no wake" travel was OK, but engine would bog down and die (unless I backed off) trying to get on plane. Also, anything over a fast idle set off a very annoying steady warning horn (which I learned was the fuel starvation alarm). Once I was back on land I found fuel leaking inside the cowling and noticed the little inline filter. Changed the filter and fixed the leak (hose clamp).
Made another trip to the lake - same issue. Tried pumping the bulb when it was starving for fuel but no help. Bulb wasn't sucking flat. It wasn't firm; it was squishy. Called some mechanics, talked to some friends, researched some forums and concluded it was in need of a carb rebuild. The labor cost was more than I could bare so I ordered kits and rebuilt them with the help of an experienced friend. This included using Chem Dip, compressed air, etc. We punched out the little aluminum circles (whatever they are) and cleaned behind and replaced them (heard this was critical). Blew all the jets out, etc. Upon bolting them back up noticed that the throttle throw on the console wasn't enough to open the butterflies all the way. Noted this but didn't adjust anything.
Back to the lake again. No change. None. Fail. Saw a guy with the same motor who had the same problem at one point. He soaked his engine with WD-40 to loosen some linkages related to the timing advance. He said it's also a good way to hear vacuum leaks. Tied the boat to the dock and left it unattended while I went to Wal-Mart. Returned with WD-40 and soaked everything. Didn't heard vacuum leaks, didn't fix the problem. Fail, again. Off to the mechanic. He ran the engine (in a tank, under some load I suppose) successfully using his fuel tank. Put a vaccuum gauge on the motor and said it was good (>6?, but I forget the unit of measure). Said it would only pull 2? off my tank. Said the ethanol had degraded the fuel lines. Replaced lines from the tank to the fuel pump. Replaced bulb. Replaced original straight connector with an anti-siphon valve. Test run was OK in tank.
To the lake. For the first time the boat gets on plane, but if I try to push the throttle any faster than just barely on plane I still get a fuel starvation alarm. Steering has an unbearable pull to the left. Back to the mechanic. He found some trash (presumably deteriorated fuel hose) in the in-line filter (under cowl). Still runs good in his test tank. His theory is that trash is clogging the inlet when sloshing around at the lake but not sitting on the trailer at his place. Says the boat is over propped (with a SS Raker 14.5x22, cupped). Says the sync and link (which I asked him specifically to check because I was concerned about the timing advance) "looked" good - doubt he followed the factory procedure here. Finally says that my issue of not achieving WOT is due to adjustments inside the Morse helm control and nothing at the engine end. Suggest that I clean out my tank (somehow) and upgrade my steering.
So this gave me some stuff to do. I tried siphoning the tank but had no luck getitng the outlet end of my siphon low enough to run steadily. Decided to pump out some fuel with the bulb into a clear container instead. Disconnect from the engine and started pumping. Got a couple of small pieces of stuff then it looked good. Didn't see any water. Noticed that the bulb was VERY slow to refill. No wonder the big 'Rude is starving. Replaced the anti-siphon valve with the original straight connector. Bulb filled quickly. Pumped a couple gallons out. No trash. No water. Made adjustments inside the Morse helm control with the threaded connector and positioning the rod into another hole. Adjusted the steer trim tab with the rear toward the direction of pull as far as possible.
To the lake, again. Hooked engine to my pumped out small tank. NO more fuel starvation alarm. Boat achieves WOT and 39mph. Hooked back to the main tank. Works just the same as on the small tank. OK, getting better. Idle is WAY too fast. Made helm adjustments there until I found a good balance of opening the carbs enough and having a good idle speed. Steering is still pulling hard to the left. Still won't push up on trailer. Still struggles at middle RPM. Returned home. Swapped the Raker for the 19 pitch prop.
To the lake. New prop yields better acceleration, more WOT RPM and a higher top speed trimming out at 44mph. Still having mid range issues with fluctuating, running rough, etc. Still pulls hard left. Back home. Found a trim tab riveted to the skeg (aftermarket). Drilled these out and rid myself of it.
Most recent trip to the lake (this time going primarily for fishing, secondarily for diagnostics). Steering is cured! Can release the wheel and she runs true. Turns to either side easily. Awesome! Still having midrange power issues. Still won't push onto trailer. Had a couple of frighting episodes a few miles from the dock where it would bog and not get on plane. Probably scared my passengers. It resolved itself somehow after letting it set a minute. Again, it would run at or near wide open. Anything else and it ran really rough, surged, etc. A time or two it would be running at or near WOT and just die (that was wild). Also had the strange trim motor killing my RPM incident but that stopped.
Next steps:
Borrowed a timing light. Would like to check timing at speed and under load (seems crazy but I read that it is the most accurate way). Also borrowed an engine analyzer. This should at least tell me my RPM but I'm wondering if I can detect misfires or incorrect timing advance if they exist. Could I have coil or power pack issues? How is the best way to check? Pulling a plug at a time, under load and under way? Upon last inspection all the plugs looked similar, if that means anything. Could my low compression be the issue? I've since ran some Seafom thru it - maybe that helped. Should I "dunk" it to decarb it and check compression again? Does the compression # really matter if they were even and if it will run 44mph? Is it worth swapping plugs? I'm leaning toward a timing advance issue still but can't find a procedure for a link and sync, can anyone explain how to do it on this engine?
I just really need this thing to run more consistently and reliably overall, and to run smoothly at the more preferable cruising speeds.
Congrats if you made it to the end of this, and again MANY THANKS!!!
The good:
The problems:
Next steps:
