84 model Evinrude 25HP, I just got this boat a week ago and I knew I should have checked the lower unit gear oil but I didn't. And I think I broke my drive shaft? Or.......??? I bought a donor motor to steal the lower unit off of but it was a 75 model I do believe and mines an 84. The driveshaft splines are different and won't line up. I also had metal shaving in the bottom of the unit where the pinion gears and final shifter is. (Not sure on the name of it) but if anyone has any info on what I need to do I would greatly appreciate it!!
