I have a 83 150 crossflow does anyone know the max output from the stator in voltage? I know that the amp output is low but it makes like 15+ volts at higher rpms. My tach does not read right and I have a replacement but I don't want to damage the new one if this is bad. I have a new rectifer coming cause the old one has a couple of bare wires and I dont want to get stuck if they corrode. Is this the regulator or is there a seperate regulator? Thaks to all!
