wegngis
- Sep 19, 2007
- 12
Like the title says, the only way I can get my 1966 Evinrude Angler 5hp to run is by placing the tank up high. By 'high' I mean above the level of the motor itself. Even then, it takes 30 pulls to get it started. Once started, the thing runs like a champ. Ran for 2 straight hours no problem. In my mind, the most likely culprits are bad fuel pump, bad line or bad connectors. What's the most likely reason this is doing this? I just rebuilt the carburetor.
