Auxlarry
- May 21, 2010
- 304
Had the boat out and after about an hour of wot running she just slowed down and quit, no overheat alarm, nothing! Got it back home and check compression and found the lower starboard cyl at 53 psi. Pulled it down today and found the burned piston and checked the overheat circuit and it is working .
It looks like preignition but I checked timing and was at 24 btdc. Not sure if this is the correct timing for this engine because my book tells me to reference the engine timing tag??
Any help would be appreciated!!
Larry
Larry
