1979 Evinrude 35HP long shaft. Model 35903A, serial number E002229. I have ordered a manual and an impeller, but I think the impeller will get here first. I've done this on my 25 Evinrude, but the 35 is a little different. From the parts diagrams on line, it looks like there is one extra connector: a stud and nut at the front. Other than removing that nut, is the disassembly the same as the 25? That is: remove the four bolts (plus the nut on the stud), wiggle the lower unit off enough to disconnect the shift rod connector, and that's it?
Thanks,
Lewis
Thanks,
Lewis
