Hey all! Been having issues with my 85 Rude 115. I've cleaned the 4 carbs. New plugs. Primer bulb goes soft and if I pump it up, engine seems to come back to life. I have a new water separator filter. There was a in line fuel filter under the cover. This has been the same way for the past 4 or 5 years. Slowly getting worse. Now have no filter under the cover, rebuild kit on the fuel side of VRO. Still using VRO system. verified alarms are working.
Will run fine for about 2-3 mins and them rpm goes down. once primer bulb is pumped up, rpm go up and no loss of power. This has been gradual over the last couple of years and am at a loss of what the problem is. Any idea's?
