I need some help with a TD-20 I am working on. Here is what I know/What I have done:
Good compression, water pump works well, magnet wheel seems strong and I I cleaned the tank out good even though it was actually quite clean looking.
I tested for spark and only had spark in one cylinder so I pulled the flywheel to inspect the coils. To my surprise they looked great-no cracks.
I needed to set the gap for the points at .020 and cleaned the points with 1000 grit wet/dry sandpaper and then ran clean dry paper to finish the cleaning.
After reassembly, I had spark in both cylinders so I added some gas and she started and ran on the third pull and I let it run for over an hour while playing with the needle valves.
I shut the motor down as it was getting low on gas and later added some more and tried to start it up...no go and when I checked I have no spark in either cylinder.
Am I dealing with bad condensers?
