old islander
- Jan 27, 2013
- 302
I guys,
I picked up a 77 35hp Johnson not running last year. Turns out it was the needle stuck in the seat so after a cleaning it runs great now. Heres the other issue. It has a knocking noise coming from inside the leg. It sounds like the shaft is hitting something when it turns. The PO said he put a water pump in it last year ( don't know if it was full kit or impeller only). The motor is pumping plenty of water with a very strong stream from the pee hole and is spitting plenty of water from the rear of the leg. Whats weird is it is also pushing a lot of water out the front of the leg (see photos). Is water supposed to be coming out here? or could this have something to do with the knocking,rubbing sound coming from the leg?
