you may have misunderstood...in the past I have googled images from google and found pics and diagrams that can help answer ?'s like yours...try going to google images and enter OMC 90 hp. turbojet
I tried that before posting. I can find the picture but can't find the diagram that explain what the connector is for. I even have the service manual it have the water flow chart but did not have one for the exhaust cover......
Racerone, the full name for this outboard is
Johnson/Evinrude 90 HP V4 Crossflow Flatback. it came with the rage14 boston whaler 1994. It was use in mostly outboard so it is the same engine. I think it is the telltail too, but I want to be very sure, does anyone have the similar engine and check where it is connected to? if it is the tell tail, it is save to block it off since it is use as an inboard and I don't need the tell tail. Thanks
