tsnapcracklepop
- Jul 1, 2015
- 8
I hope I am posting to this evinrude forum for mechanical problems.
1966 twin cyl electric start. Runs with a spray of ether, will not run on its own. My friend revived this boat after it sat for a few years by swishing out the tank, filling the tank, then taking out on water, where it ran about 3 miles, slowed down in rpms, and he limped back to dock at very slow speed.
I found the tank with tar on the bottom, and fuel system containing h2o and bad fuel. Cleaned system and replaced hoses, cleaned carb and fuel pump. Attached a temporary tank.
The bulb gets hard, and some fuel flows thru the fuel pump (cleaned and tested for positive and negative pressure off engine) by sucking and blowing, I can hear the diaphram and it pumps fuel off the engine when I suck and blow on the air line., )
When the engine is cranked by the starter, the bowl never seems to fill, by checking the drain. I am
checking float and needle valve today for setting.
Enigine will run with starting fluid, but not off fuel system. I have not put a guage on the crankcase attachment on the port side, but did check for vacuum and alternate pressure , while cranking engine, at the hose to fuel pump and at the crankcase nipple. I did this with my finger and detected NO pressure in either direction.
The engine runs great on starter fluid, but I suspect it may have a bad crankcase seal, losing fuel pump operation, and losing ability to draw fuel mix thru intake valves. When run on starter fluid, the bowl does not fill.
1) It seems like i should be able to at least feel some alternating pressure changes from the case nipple with my finger??
Also, I am not sure what the mechanism is on a shaft that runs from the flywheel on a lever down to a shaft which operates 2 ajdjustable tappets above the cylindder heads on the starboard side of the plugs. The top seems to run in a cog on the flywheel, similar to a recoil starter engagement. I do not see this mechanism in the field service mannual linked to this site on the powerhead diagrams.. It could be figure 3.1, which seems to be missing.
2) Compression release?
Appreciate any ideas! I have been lurking on this topic for a couple of weeks now, but have not yet nailed this down.
I am also revivng, for myself, a 1953 goodyear, which has sat for at least 20 years when I figure out this evinrude.
