thyNemesis
- Apr 19, 2013
- 73
Hello,
I've had a problem with my fuel pump and I think I found the problem. I wanted to ask for any advice on how to go about repairing it myself.
I had taken apart the fuel pump and noticed when I opened it up I had two extra parts that were not in the parts break down chart. It was a rubber seal and metal retaining disk that prevented air from the air pump going into the fuel side. It went on the fuel side shaft.
I determind that the 4 little nubs that hold the metal retaining disk down onto the rubber shaft seal are almost gone. I was wondering if anybody had any hints or advice on how to go about repairing this. I think the plastic housing is made from ABS plastic, I could be wrong.
I was thinking of using a very small tipped soldering iron (that is made for surface mount electronic components) and attempting to melt some lips that will hold the metal retaining disk down onto the rubber seal. I know not to melt through the plastic housing! Would it be possible to find some similiar plastic and use it as solder to create some new tabs onto the old worn tabs?
The tabs seems to hold the metal retaining disk edges once pressed down into the hole, preventing the metal retaining disk and gasket from coming out.
I've attached a few photos on the parts in question, the rubber seal and metal retaining disk.
Thanks.
Thanks.
