took my boat out for the first time this year Friday and broke a piston ring. I pulled the head today to access the damage. broke off part of the piston end and looks like it broke a small piece off the bottom one of the ports. Also see a small crack. Is this repairable? I couldn't get a clear picture of the exhaust port. can I weld the crack inside the port? the motor is a 140 hp omc seadrive. My thought was to bore the 1 cylinder. the other 3 are at 120psi and you can still see the cross hatch marks in the cylinder. tried to upload pics but couldn't
