I have a 1989 Johnson 15 horse that won't stay running. It has a new fuel line with a new bulb and fuel ends. It is getting good fire and has new properly mixed fuel along with having the carb cleaned with a new needle and float put in. When you crank it, it will start and stay running about 3 seconds and then die. You can do this all day and its always about 3 seconds before it dies. Choke and the slow speed need valve can be in any position and combination and it still won't work. Any ideas? Thanks in advance!
