Looking for the dimensions of the Anode Screw (bolt) for a 1986 Evinrude 35 HP.
Don't have the Motor code, but from the diagrams I have seen is is the same as is used on a 1986 35 HP with motor code E35ELCDE
OMC/Evinrude/Johnson part number is 0328096.
I need to know the length and diameter.
Also Is this a fine or coarse threaded screw/bolt?
Many thanks hope someone can answer!
/Jeff
/Jeff
