weezerr2183
- Oct 21, 2010
- 20
I have a 1981 35hp Evinrude. I believe it may have a 50hp carb on it. Is there some way to determine if this is true? Like checking jet size or something similar? I pulled the bowl and the jet set is just a small brass tube inside a larger brass tube with four holes, two on each side. There are no markings on them, numbers etc. The carbs I'm used to working with have markings on the jets. How do I determine what jet size that I have? What are the stock sizes of the 35hp? 50hp? Would a change to larger jets be the only difference between a 50hp and a 35hp? Or would the reeds have to be changed also?
Any information would be appreciated and thank you in advance.
