I have a 1995 90 hp johnston motor that the heat alarm goes off.
At first when I fired it up and ran it some the alarm went off.
It was puttin out waster through the pee hole.
Found that the left cylinder was hotter than the right one( standing at the back of the motor
So I pulled the thermostat housing off and found that the left thermostat looked bad and stuck ,so I replaced it.
It was also time to rebuild the water pump.
So instead of rebuilding I bought a new water pump assembly and installed it.
Then fired up the motor and still the alarm went off. Now both heads get hot and the little rubber hoses at the thermostat housing also get hot and soft.
What have I done wrong or what can be the problem.
The old impeller did not look allthat bad.
Need help.
Jeff
Need help.
Jeff
