Replaced needle valve and float the other day on 1980 Evinrude E35ECSM and now motor will not open up. Idles fine and runs smoothly at trolling speed but as soon as you open up the throttle it dies. It gives a good attempt to accelerate but appears that it not getting the fuel. Float seems to be set level to the carb body.
Did nothing else to the carb except spray some carb cleaner and use air to blow out. No welsh plugs removed and replaced.
Any suggestions?
Any suggestions?
