my power tilt and trim motor has quit working. Coming from the relays I have power but motor is in down position.How do you raise it up to get to the ptt motor.how do you remove it to get it repaired or replaced.also can you recommend someone to work on them.I would aperciate any advice i can get. Thank you in advance KC
