gwgautney
- Aug 28, 2013
- 283
I have a 98 !75 Ocean Pro that has been giving me some issues. It runs fine other than when you get it above approx. 4000 rmp's. I restored boat over the winter and before I started there were no problems with it. When I got done with it and took it out the first time it ran fine at 4000 and below. Once you give it more throttle it will start accelerating for 10 or 15 seconds but then it will start bogging down almost like it's starving for fuel. I have rebuilt carbs and had it tuned up at shop due to an idle issue I had. There was fuel in the tank when I let it sit. I treated it with stabil and then put some sea foam in it and ran most of that out. It's a 37 gallon tank and I just put 29 gallons in it last weekend so I feel like all the old fuel is gone. The only thing I did with tank when I was working on it was pull out the pick up tube and inspect it. I pulled the screen out of it and checked it out. Is it possible that I messed screen up when I put it back in and that is causing it? Also I changed anti-syphon valve. I did not change hose from tank to the motor should have but didn't. Any advice on where to look would be appreciated.
