My '77 Evinrude 140 HP Bubble Back will run fine on a water hose attachment but wont hardly start and idle on the lake (it cranks over fine). If you trim it out high it will start and you can get it going but it has a severe loss of power taking off. Once it gets planed out it runs OK.
As I see it the main difference is the back pressure of the water against the exhaust.
I've got to get it on the water or in a barrel to re-create the problem and the first thing I'm going to do is a spark test along with a timing light around each wire as I'm testing that cylinder. I believe I'm going to find a weak or random spark. If I do, would this make since why it wont run in the water but OK on a hose?
I think this motor has two power packs (one for each side) but I haven't looked at it in a while. I fired it up on a hose and some friends took it out and had trouble. Is there any common problems with the ignition system on this model? I've got a slightly older 85 HP (parts only) with the same looking ignition modules so I was thinking about swapping one out if the spark test fails.
I had erratic spark problems with my '96 175 HP Johnson with nearly the same symptoms, but also dying, and changed the single ignition module and all 6 coil packs and it fixed it.
Thanks for any help on this one
