I have a 95 Johnson Fast Strike and was cruising the lake about 3500 rpm and engine just quit. No spark on any plug. Stator putting out 32 volts a/c. I have been reading and trying to find out as much info as possible to diagnose problem and have ordered service manual but haven't received it yet. I have a few questions maybe would help to get me started diag in right direction:
1. Should the two yellow wires from the stator ring together?
2. Where is the rectifier located on this engine? There is a rectangular piece with 4 bolts on top of engine and four wires is this it? 2yellow 1 gray 1 red
3. Ohms on brown to brown/white wire from stator measure 1080 ohms. Does this sound correct?
4. Should there be battery voltage to the power pack behind the coil packs?
Thanks for any and all help. Would really like to get this engine started and get back OTW.
